Mick1988
W.A. Cruise Moderator
- Apr 6, 2008
- 786
- 14
- 18
- Age
- 35
- Location
- Perth, Western Australia
- Website
- www.sarichtechnology.com
- Too many to list......
do you have good spark on all plugs
what is your long term fuel trim at
No spark on plugs 1 and 3. Those are the two leads that shock me when holding them near headers to test for spark. Tried new leads, new coil and new ignition module no difference.
Purge canister I would presume sometimes throws a code 97 error and is simple enough to replace
Is that the same as an Ecotec one? Haven't tried changing that yet although unlikely to disable a whole car it is a possibility.
How's the fuel filter n spark plugs? No mention of changing them?
Plugs replaced 15,000km ago, don't have spark on 2 cylinders before even getting to the plugs. Fuel filter I haven't changed but fuel pressure to engine bay is normal.
crank angle sensor.
Tried a new one and a second hand one off a known running motor.
Might be your fuel pressure regulator. Get a pressure gauge and tee it to the delivery line and check fuel pressure is to spec. Compression , fuel and spark....
Fuel pressure is good. Tried an entire fuel rail and injectors off a known running L67.
I had a same problem with my v6 and turn out to be a simple loose plug on one of the sensors was not click on all the way.it drove me mad for 2days trying to fix it to.
Which sensor was it mate? Only ones I haven't unplugged and plugged back in are oxygen sensors, knock sensors, purge solenoid and coolant temp. Everything else has been unplugged and re-plugged when swapping parts.
I have just tried ECU BCM and key from a VT Exec (Ecotec) both with the L67 memcal and with the Ecotec memcal which also made no difference. Also checked and both heads have path to earth block has path to earth and charger has path to earth. Have tried changing relays around to no avail also.
A Holden dealer has asked for my car to be displayed at their 20th birthday celebration so would really like to get this running. I am also considering selling it so not having to pay rego again in December would be a bonus.
