VT losing coolent even when engine off
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by aussieakito, Nov 12, 2012.
  1. aussieakito
    Melbourne, Victoria
    Hey guys, recently did a radiator flush.
    put the new stuff in and yes its bleeded and all.
    But when ever i check under the radiator cap the coolant is always VERY low in there yet the reservoir is full, Its like the radiator is putting it in the reservoir but not taking it back out, checked the cap it looks functional.
    But for it to happen even when the car is off and cold is strange. no leaks under the car and no steam in the exhaust or fluid in the oil.
    WHERE IS IT GOING!
    Car isnt over heating its staying between the 1/4 and the half markings
  2. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
    Thermostat not opening?
  3. aussieakito
    Melbourne, Victoria
    If it wasnt opening then the car would be getting hot wouldnt it?
    ALso when i bleed the system from the valve on top it worked :S
  4. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    Try another radiator cap. If the rubber has gone a bit hard air will get sucked into the radiator instead of sucking coolant out of the overflow bottle when the engine cools down.
  5. aussieakito
    Melbourne, Victoria
    Just went out and bought one, waiting for the car to cool down so i can put it on. (Crossed fingers)
  6. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    Could be intake manifold gaskets leaking. Wouldn't be the first VT owner losing coolant through there
  7. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    caps looks ok but sounds like its ####ed
  8. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    make sure cap is suited 4 use with a reservoir should b written on it.
  9. aussieakito
    Melbourne, Victoria
    got the new cap on and it solved the problem :)
