TomFarrell
Hi Team!
A little while ago, I posted about my 1999 VT having issues with the cooling system and we resolved that it was tranny fluid in the system. I have since had the radiator replaced and the fluids topped up. But now I am facing a slightly less worrying issue of the fluid in the cooling system somehow disappearing. I have ruled out a broken head gasket, as the engine oil is not a milky like substance, and its not the tranny oil either, nor is there any oils getting into the radiator either. I have also ruled out a leak as there is no evidence of this.
What are some other areas I should be looking at?
For now, I'm just putting in regular tap water until I can fix this issue.
FYI - I replaced the thermostat approximately 13 months ago myself.
