stuey.89
- Aug 15, 2011
- 25
- 0
- 0
- Age
- 34
- Location
- Sydney
- VT Berlina 5.7L
Ok fellas so im still in the process of removing my oil sump and have hit a slight hiccup..
Vt ls1, I have everything I need (I think) i went n got an engine crane, ive removed the bonnet, and from what I understand, I need to undo the engine mounts, support the engine using the crane, then undo the k-frame low enough to get to the sump bolts.... my question is!
Have undone the drive side engine mount bolts using a ratchet with 2 extension bits, a uni joint and an 18mm bit... the passenger side is my problem, I need to remove my heat shield, air box, and by the looks of it there are some metal lines running straight over the top of the bolt... I think its the tranny fluid lines... I suspect I have to move them but am not sure if theres another way?? Im confident that once I get this last bolt undone I should be able to get my car running the same day and cant wait!!!
