vt manaul conversion
bunup
vt exec
hi there all ! ive got major probs with me conversion on me v6 vt . ive just finished putting a manaul in & ive changed the wiring loom & now the bloody thing wont start ! it justs cranks over ! evry now & then & it wont stay going so if any one can help me at pls:bang:
vtmanualv6
VT HBD 3.8L
how many times have you gone over your work checking everythings pluged in? Sounds like some sensor may not be conected or a dud wire? Crank angle sensor ? Just a wild guess. Did you change your ecu as well ? Need more info
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yeah did you change the ecu and bcm and keys etc to suit
bunup
vt exec
ive only changed the wiring to the computer & the one around the batt . no i havnt changed the ecu
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
I'm pretty sure theres a manual ECU and an auto ECU.
From that I'm guessing manual ECU's are hard to come by, which may be why the person who sold you the conversion kit (possibly) avoided mentioning that.
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
I believe the ECU's are the same, but the tune (memcal) is different.
The memcal experts around here should be able to confirm.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yip...............
kart_racer
Races karts
VT Acclaim 5M
Yep, ECU is the same, memcal is different.
All you need to do is change the memcal, not the ECU, BCM or key...
Easy :)
