vt missfire, tried the usual things
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by motard_mike, Mar 1, 2010.
  1. motard_mike
    motard_mike New Member
    vt wag
    ok i have a vt wagon with 220k kms on it. the car gets used for towing 1000kg+ ski boat every weekend and has developed a miss at 1800-2500 rpm when under load. if i shift down manually and get the revs up it pulls like a champion but that doesnt help much when trying to get up a boat ramp and the car wont even move. I have had the ignition system tested and it came back fine. First i was told it had a leaky inlet manifold gasket and loose injector seals replaced all that. since then I have been told to replace the coil packs... did that $150 same problem. CAS was next $80 same problem, Ignition module $170 same problem. now the mechanic wants to do the injectors and im sick of throwing money at it. is there any way i can test and find teh exact problem before i give up and get a au falcon wagon?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    How old are your plugs and leads?
  3. motard_mike
    vt wag
    leads are 6 months old max, plugs not sure to be honnest. if aftermarket are ok i guess thats a cheap next thing to try.
  4. motard_mike
    vt wag
    genuine $20 for 6.... couldnt beleave it! ill put them in tonight and see if that helps.
  5. BowTie
    BowTie Active Member
    VS V6 Acclaim
    If no luck with that^
    then do a dry/wet compression test.
    I have blown head gaskets between 1 & 3 with no external signs other than a severe miss.
  6. motard_mike
    vt wag
    head gaskets also done, that was a seperate issue so didnt mention it. also done new radiator and cooling system inc thermostat.......
  7. holdenvtman1123
    holdenvtman1123 Improvise Adapt Overcome
    Broken Hill NSW
    VZ Adventra LX6 2006 3.6L
    i use iridium plugs and get 100k km a hit out of them. they cost 20 bucks each
  8. Ozzie
    Ozzie JCCC Warrnambool
    Warrnambool
    Ozzie'z Supercharged VY Calais
    well arent you a sucker for advertisment.
    why buy high heat plugs unless ur v6 is stroked runnin meth or avgas?
    you dont pay more because they last longer.
  9. crisp5.0
    crisp5.0 New Member
    vt ss 5.0l
    ozzie i just replaced my dizzyin my vt 5.0l now i have a slight miss or choke or somethiong under accaleration any ideas its only happened since new dizzy
  10. codeunknown
    codeunknown New Member
    near bundy in qld
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    loss of grunt from a dizzy...can be due to a few things...a leaking coil...or a coil failing under load..
    check that ...
    also a bad earth...bad earth on cars cause issues like car computer issues....battery charging....and anything that requires a earth base feed...so check and clean the earth points..add extra straps if you like...
    and clean the battery terminal...
    check the high tension leads and plug leads for ""air pressure gap"" this caused by shoving the cap on and it traps air inside...as the car gets it so does it and hot air inside lifts the plug leads on and off contact...
    how to fix? easy...when you fit the new leads on lift with a small flat screw driver...and allow air to escape while you push on...once on remove the screw driver...
    known to be a issue with brand new fitted leads and or dizzy cap..
    and this misss that is new... could it be due to splippage in the transmission or clutch..given you pull --tow allot ? perhaps if a auto trans when was the last time the auto trans filter was renewed and new oil given to it..in its hard life of towing...:)
    and perhaps the kick down needs adjustment as well...and in general a auto trans service..
    if the car is manual...the same rule applies to clutch ?
  11. motard_mike
    vt wag
    well guys i put in the new GM plugs.... and bam she runs perfect! the old plugs even looked good and where NGK items. any way thanks for the advice and i still cant beleave that the brand of plugs made that much differance!
  12. mickymodge4
    mickymodge4 Member
    vn calais
    hey mate is your car on dual fuel????
  13. mickymodge4
    mickymodge4 Member
    vn calais
    if so which gas plugs part numbers were they????
