losh1971
- Jan 17, 2010
- 22,628
- 22,434
- 113
- Location
- North Tas
- VE Series I SS Ute
Right now you need to refit your old rocker assemblies. There is no adjustment as such. You measure preload and go from there if the new rockers have to much preload then you could shim but until you have measured the preload and posted the results you won't know what thickness shim to need to have. Ideally you will measure the preload with the Hi Ratio Rockers and then order rods to suit. Too much preload and you could **** the cam.
