Glaze
Hey so I’ve been having problems starting the VT. Got a new remote attached to the original head from mr minit worked for a week flawlessly then buckled it.
Car cranks but it’s as if fuel isn’t sending but the pump primes and works well under load, also once the car decides to start there’s a screech noise (like you’re tearing apart cloth material) in sync with the drive belt as the pulleys spin (noise intensifies when I accelerate but slowly disappears) Starter, battery and alternator are ok.
I interchanged the spare and original key to start the car for that week and then use the new key when it buckled to figure out if the key was the problem. However the new key failed. Note: whenever the car starts normally the noise I described does not occur. Very confused... yet I’m suspected alternator is buckling it
aside from this, today started the car but it immediately cut out and then the thermo fans turned on?? First time ever occurred. Beginning to think there’s a grounding issue because my high beams changes revs slightly when idling. It’s also been dropping revs rapidly to about 200 back to 900 momentarily (usually when idling at lights after coming to a stop) then runs as if nothing happened.... all the standards been checked eg belt pulleys voltages even the grounds around the car..
Apologies for the life story but I’m sick of everyone looking after their pocket old mate just said he found few BCM codes and wiped it off claiming he forgot the codes etc etc and I can’t find any info for this issue that seems to be coming from multiple flaws might just wreck it any advice/help is well and truly appreciated!
