VT Over Heating & Missing problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by zebono2, Dec 20, 2012.
  1. zebono2
    zebono2 New Member
    sydney
    VT commodore
    VT V6 1997 Auto
    So a while back my VT started missing under light load when going above about 70km
    If i put my foot down i would to fine.
    So i dun a full service on it
    plugs
    leads
    fuel filter
    air filter
    oil filter
    oil
    cleaned the throttle body
    And it made no difference
    A week later it over heated so i looked into it more and worked out the head gaskets needed replacing
    so i put a vrs kit in it got the heads cleaned tested and skimmed
    cleaned intake to remove all the carbon deposits
    Replaced the intake gaskets
    flushed radiator and put in new coolant and
    bled the system by turning heater on fill getting up to temp and opening the bleed screw.
    Replaced fuel pump
    replaced battery (it failed sitting in the workshop for a week)
    the miss was still there
    and the other day it overheated again but it did not lose any coolant.
    i have been driving around for about a week and it has not overheated again
    I'm stumped
    i don't know why its missing under light load
    i don't know why it overheated
    Ive checked the coil
    6-3 6.04ohm
    2-5 6.06ohm
    4-1 5.96ohm
    ive checked the leads
    1 1.61ohm
    2 4.45ohm
    3 2.67ohm
    4 5.34ohm
    5 2.63ohm
    6 4.83ohm
    Does any one have any ideas
    Thanks guys
  2. edals
    edals Well-Known Member
    Here
    VE Equipe
    Did you Change the Thermostat also ? They can cause over heating problems.
    As for the Miss, Id say coil packs. I had the same issue coil packs only failed under load but tested ok.
  3. Ghost
    Ghost Donating Member
    Junee New South Wales
    Vs Commodore berlina Sedan 1996
    Yeah +1 for both
  4. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    Some of your leads seem to have a lot of resistance.
  5. wortus
    wortus Active Member
    When you bleed the system you really need a head of coolant above the level of the bleed screw as opposed to the pressure created when the coolant is hot. What I do to achhieve this is with the motor cool take off the radiator cap and insert a gatorade or coke bottle or similar at the cap end which has the bottom cut off it. I seal the cap end by wrapping it in electrical tape first so it pushes into the radiator. Clamp off the overflow tube and fill this bottle with coolant then undo the bleed screw, assuming there is no air trapped in the heater core this will remove any trapped air.
    Those spark plug lead resistance readings do you mean kohms? hort leads are good if below 10k (10,000 ohm) and long leads are good if below 27k (27,000 ohn) resistance assuming issulation is not damaged.
  6. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    This is out of the Gregories manual.
    Ignition coil resistance (at 20 to 30 degrees)
    Primary:
    3.8 litre V6..........0.3 to 1.5 ohms
    Secondary
    5,000 to 7,000 ohms
    Spark plug wire maximum resistance.
    Left side.....10,000 ohms
    Right side...27,000 ohms
  7. zebono2
    zebono2 New Member
    sydney
    VT commodore
    sorry for the late reply
    Thermostat was replaced with a new one
    i might try getting one coil pack n replacing one at a time n c how it goes
    what about the overheating?
  8. Catchy
    Catchy New Member
    98 VT Executive
    Did you check the new thermostat and ensure it opens fully and @ correct temp?
    Pressure test both your cooling system and radiator cap, ensure it's relieving at specified pressure and the vacuum valve is working.
    Does it only overheat at idle, or while driving down the freeway or both? Thermofans kicking in?
  9. zebono2
    zebono2 New Member
    sydney
    VT commodore
    i have not checked any think yet but today it was 37deg and the car was running at 104deg i was cruising at 80k with the ac on
    ill test the thermostat
    the radiator cap is new but ill check it
    how do i test the cap and cooling system (ensure it's relieving at specified pressure)
    and where is the vacuum valve and how do i test that
    yes the Thermo fans kick in
