Welcome to the World of "Knock Retard"
If using inferior quality fuel, running stock or higher boost or hot weather the ECU Engine Knock Sensors will pick up a bit of incidental detontation and start removing Timing from your Spark Timing Advance Map.
The ECU Knock Interaction can remove as much as 14* Timing moving it into negative timing a some points to try and curb would-be spiralling detontation.
It is very normal for a Super6 to feel good sometimes and crap other times. It will be most noticeable on hot days or times which the engine is very hot from being driven a long time.
Ways to cure:
1) Run ONLY BP Ultimate 98+RON Fuel ALWAYS
2) Nulon Pro-Strength Octane Booster
3) HeatShield for LHS Exhaust Manifold
4) Improve CAI (No PODS !!)
5) Cooler Thermostat (81*C)
6) In-Cabin Fans Switch
7) Intercooling
You can reduce the "Good Day" vs. "Bad Day" power-up and down moods of the Super6 by following the simple above guides.
Hope this helps.
Regards
Tonsta
All of it would apply to Factory Super6's they are reknowned for it and we have seen it countless times.... how much of that would apply to factory S/C V6's?
... You'd think itd be design spec to be able to operate properly..
