vt rear camber kit installation
scozzman
46
vt
hi all. does anyone know how hard it is to install a rear camber kit on a vt. how much are the kits and are there different types.
thanks in advance...
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
yes i would like to know the same thing......and what it would cost?
mistaken
... pimpin it VT stylez
VT
*bump* im wanting to know aswell ;)
scozzman
46
vt
still interested.... any info appreciated
cheers...
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Go to www.k-mac.com.au You can down load an instruction sheet for your model The kit costs about 300.00 buck takes about 1hour to fit . This kit comes with four bushes and an extractor tool for removing your old bushes . also you must get a four wheel alignment
Hope this helps
vy_pete05
Please rate my feedback
Perth, West Aussie
'04 VY Exec SII
for the trouble you go through, get it done at a workshop, i got it done and its a relief not to have to do it yourself, and its definitely rewarding, better grip on the road and your rubber will last longer :D
justbad4you
IF YOR NOT A HOLDEN
hey pete were did you get it done and what did it cost you......?,,thanks mate take it easy............................
vy_pete05
Perth, West Aussie
'04 VY Exec SII
PEDDERS in wanneroo, a local suspension place for me, i honestly cant remember how much it was, around $400ish though, hope it helps mate
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
That sounds about right Pete , i got a quote from Pedders the other week of $395.00 .Thats Drive in drive out including a wheel alignment .
If you are going to go it yourself make sure you get a rear wheel alignment A.S.A.P as you will wear your tyres out in no time if the settings are wrong
vy_pete05
Perth, West Aussie
'04 VY Exec SII
confirmed with a mate of mine, $385 for a kit to be fitted (including wheel alignment) however that is only for a HALF camber kit...for the full camber castor kit to be fitted (which is highly recommended) it will be around an extra $100-$150...when i got mine done they said that a half kit would be sufficient, go the full kit, for the extra cash, i was a little tight at the time and when a "professional" tells you its sufficient you generally go with the flow...:D
