VT rear middle seat, removing plastic bit?
50LTRv8
VT V8 Calais
Hey Michael
To remove that part of the seat, remove the bottom part first (there are tabs that you pull forward at the base of the seat in the foot well.
Then you will see a bolt at the bottom of the right and left hand sections of the seat, remove these and slide both sections out.
Now take a look at the cup holder bit, there are 4 bolts you will need to remove and the center section lifts straight out.
Hope that helps
