Hey Guys. I was just wondering what should a VT S revs be at, at 100km/h. Mine has been sitting at close to 2500. The engine is in great condition and done 232000 cheers guys.
thats a little high, sould be be about 1800 or near abouts i think, is the torqueconverter locking up? and fault codes? ie count the gear changes 1 - 2 - 3 - 4 - t c lock
Yeah ive been looking at the forums and alot have been saying the torque converter. Ho wsure are you and do you know hows mach it would be.
Yeah well im pretty worried about it, a commodore shouldnt rev that high @ 100kmh. Im hearing alot about torque converters. How much r they??? Ther r no error codes appearing. Ive replaced sparks and leads, new exhaust. oli etc etc
Is this a new problem or was it like that when u got the car? 4:11 diff gears will get u revving like that. Alternatively if it is standard ratio (3.07 which should rev at about 1450rpm@100km/h) then that means the tranny isn't even selecting final drive (4th with convertor lock up) and it is more than likely staying in 3rd with or without lockup. Don't worry about the convertor, might just be the lock up solenoid in the tans itself which sends the signal for the convertor to lock up or a calibration issue. Ur box is fully controlled by the comp so it will more than likely be electrical. Have you tried checking DTCs?
Diff isn't the problem, just be good to know which ratio u have. Did the car have this problem when you first got it or did the rev problem come on over time or suddenly?
Im not sure i havnt taken it on the hway until yesturday and it was at 2500 rpm. I need to know wat the problem is casue i dnt want 2 spend money on something that isnt the problem
Next time u hit the highway doublecheck that the shifter is properly in "D". It may be out of adjustment for some reason which would explain why it revs so high. Not many things go wrong in the tranny like this. Did u just buy the car?
Yeah i did frm a holden dealrship. Wen i was driving i did check that it was in gear and yep all was ok. So i fell up **** creek on the 1
U have warranty, take it back and don't take no for an answer. It is their favourite answer in my experience
Well apperently they didnt keep it under warrenty ****ing holden lol, well mate thanx 4 ya help, ill take it to a mecanic and tell him about my plight.
Yes you will pay more from a dealer and I reckon its the statutory warranty. How long ago did you buy it? Not sure how long the warranty runs for it maybe 3 months from memory, in Victoria. Also when you drive it does it sound like it is kicking up? count the gears and see if it kicks up when you pass through speeds. It should kick up gradually if you gently accelerate to 100. I think mine will go into 4th at just over 80 if im driving smoothly. But then again even if I hammer it all the way to 100 i'll feel it kick up once i back out of it and start to cruise. Take it back to the dealer, and just get them to road test it. You will probably be surprised as normally its not that big a deal for them to fix it if they only have to look at it once. It may even just be a matter of them plugging in a tech2 or something like that and resetting something...
Thnx mate i bought it lik 4 wks ago so ill take it to the dealership and let them have a look at it but if nothing else wat could the prob realistically be?
Hey guys i just went for i drive along the hiway...it doesnt semm to be sellecting over drive thats y its reving so hi.... so wats the deal
