Once again thats interesting cause I recently had a flat tyre and I had to call RACQ to remove the standard Commodore rim since it was so tight where it fitted over the hub so it must have latter rims fitted.
I returned home and took off the other 3 rims and they all had the same problem so I put some grease on the hub hoping to improve the rim removal next time.
I want the 16'' rims painted flame red and fitted with whitewalls and baby moon caps so will I need the centres machined in a lathe or could I use a small grinding wheel on an air grinder.
