vt roller
Bowdovh
Vh commodore , vs statesman
ive come across a vt roller engine thats been rebuilt with stroker kit. just needs manifold and top end bits how much is needing to be done to put this engine into my vh with carby setup
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
When you say manifold and top end bits, does that mean heads as well, or what? A bit more info would help.
Sabbath'
Redblock Jesus
80 Series// MK5 GTi//
You'll need a different K-Frame, Gearbox, Tailshaft, Fuel Pump...and then answer the question that Ian asked.
Bowdovh
yes heads come with it its running in a car at moment but he will be taking group a manifold of it so k frame needs to be swapped out for a vt engine. cant i just change engine mounts
Sabbath'
Redblock Jesus
It can be done, but there are benefits to using a newer K - Frame.
2INIL8
40
VH COMMODORE 308
Use a vn v8 k frame and vn v8 steering rack,gives a hell lot more pipe clearance.
If you use a vh k frame the headers hit the rack and sump.
Apart from that use vn headers and its a direct bolt in.
Also you need power steer lines etc and it moves the powr steer and alt
opposite sides to a vh 308.
2INIL8
40
VH COMMODORE 308
Forgot too you need an intermediate pwr steer shaft from a VL 6cyl.
Bowdovh
doesnt sound to hard thanks fir the tips
hq-racing
HSVR-28
S.A
VT L67 DAILY, WORKED VR CLUBSPORT WAGON PROJECT
ive jus rebuilt my vt 5.0lt and its not the cheapest, my brace that holds the lifters in broke! good luck finding another 1 if it doesn't come with it other wise youll have to buy the t-bar lifters which are $700 plus! cam lifters and all the other stuff are through the roof aswell and I got all my parts at cost price..
what exactly do you mean minus top end bits?
mr j-man
GC
VH SL/E 355
what cam does it have?? that will determine your manifold and carby selection. If its a decent solid roller cam youll need a single plane or if its a mild hydraulic roller just a good dual plane intake such as torque power and the likes
im guessing you will need a electric fuel pump, reg and some fuel line..depending what you've got.
its not as simple as you'd expect.
whats in the car atm? ie box, engine ect
