VT running lean/rich
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by fyrbrd, Aug 15, 2011.
  1. fyrbrd
    fyrbrd New Member
    Pakenham
    2011 WM Caprice V
    Anyone know how to fix this???
    i have my malfunction light come on recently the exhaust smells different smells like its running rich, how do i fix this problem without paying 1000's as i have learnt fixing things yourself are more cost effecient then taking to a mechanic seeing as they charge $480 to do radius rod where the part cost me $150 and 20mins of my time with the wrong equipment...... so go figure.
    any help would be appreciated
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Try replacing your oxygen sensors.
  3. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    look up what code is turning the malfunction light on then replace that part.... if it not fix it
    and same code comes back on its a complicated problem probably...
  4. fyrbrd
    fyrbrd New Member
    Pakenham
    2011 WM Caprice V
    ok ill try replacing oxy sensor first than move on from there thanks for the help guys
  5. CHA53R
    CHA53R New Member
    vic
    vr wagon
    Check your codes first before replacing it. Might be something else. Why spend money on something that might be.
  6. accentstencil
    Eschol Park, Sydney
    Oxygen sensors should be replaced every 80,000-100,000kms because they lose their efficiency over time and they won't necessarily log a fault code. If they have never been replaced it would not be a waste of money.
