VT Spac FE2 suspension vs STD
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Black Lines, Mar 19, 2011.
  1. Black Lines
    Black Lines Black Lines
    Gympie
    VT Aclaim
    Hey people, can anyone tell me what the actual diferance is with the Spac vt suspension compared to the STD, apart from being a bit lower? As I can't physicaly see any changes with the springs, shocks or sway bars but a huge diferance in handling? I'm trying to take the susp off my Spac onto my Aclaim and want to know what parts to change?:confused:
  2. sus_038
    sus_038 New Member
    VT S-Pack S2
    All the difference is, is that its a bit lower and much stiffer, but should fit straight in... someone might know more about it... :)
  3. Black Lines
    Gympie
    VT Aclaim
    Thanks, I have recently got a workshop manual and it states that the front stabiliser bar is 27mm (1mm thicker), front springs are shorter and thinner, no specs on the rear tho. Just if anyone wants to know. It doesn't really explain how the back tyre lifts off the ground first when I jack up the front corner tho :hmmm:
