VT13
- Jan 23, 2016
- 89
- 35
- 18
- Location
- ACT
- VTII Berlina V6 Sedan
Just go to the SSV website, they have all types. Send them an email with a picture of yours as installed and the rough dimensions of length and width. They will hook you up with a new replacement no problems.
By the way, if you do replace it, which I think is a better option than sourcing and installing a high mount, I had no problem replacing mine without removing the spoiler. I just took out the screws and it popped down a few inches, cut and stripped the wires for the old lamp assy and then cut all but 4 inches of the new lamps wire off and soldered up. Good idea when joining the new wires to stagger the cut, maybe an inch separation for each solder. This just stops making the join to fat to go back through the hole once you insulate the wires.
