VT SS Blower fan doesnt work on high?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by IBLOWN, Apr 26, 2011.
  1. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    Having a problem with the wifes SS.
    When you switch the fan speed to high the whole A/C turns off aswell as the blower.
    I can hear a click somewhere in the drivers side dash area but thats it.
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    sounds like you need to replace the relay in the spot with "blower" on it, in the fuse box behind the drivers side lower dash cover
  3. IBLOWN
    Yeah sounds like where the clicking comes from. I'll swap it with another and try.
  4. som
    som New Member
    thorneside qld
    vt executive
    thanks boonz,i've had the same problem for 3 years and assumed it was the switch.took your advice $8.00 for a relay and problem solved.cheers
