Vt ss ls1 cut out while driving now wont crank over
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by VTSS Adelaide, Nov 29, 2018.
  1. VTSS Adelaide
    VTSS Adelaide New Member
    Commodore Vt ss
    Car was running fine then just cut out when i stopped i tryed starting it with no luck bypassed fuel relay still no luck ran a wire to fuel pump that worked. then the cranking suddenly stopped so i bypassed the starter relay and that worked but wont crank by key i changed all fuses and relays its got me stumped as to what it could be!
    Can you plug a obd2 tool up even tho it wont crank or start ? Could it be a ecu , bcm or pim? Has any one had this problem? Any ideas would help thanks
  2. BowTie
    BowTie Active Member
    VS V6 Acclaim
    Yes. Obd2 will tell you what it is.
  3. VTSS Adelaide
    Commodore Vt ss
    Thanks mate appreciate it will give it a shot
    BowTie likes this.
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    I didn't think an OBD 2 tool works on VTs?
  5. BowTie
    VS V6 Acclaim
  6. Lex
    Lex Active Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    v8 Yes.
    v6 No.
    losh1971 likes this.
  7. Lex
    Lex Active Member
    Geelong Victoria
    Sorry, got it wrong again.
    To be exact series 1, 5 litre No.
    Series 2 5.7 litre, Yes.
    BowTie likes this.
