vt ss oil pump (oil light come on)
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by evildemon43, Feb 16, 2014.
  1. evildemon43
    evildemon43 New Member
    maryborough
    vt ss 5.7
    ok my VT SS has the oil light come on and the engine has a little knock when I start it but if I give it a quick rev it goes away would it be the oil pump I got no idea
  2. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    Are you sure it's got plenty of L10 in it.
    Could be....or a partially blocked gallery, or the pickup in the pump is blocked.
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The relief valve in the oil pump could also be sticking. Have you had any work done on your car recently? Sometimes cam lube can cause a relief valve to stick if the oil hasn't been changed after the cam is run in. I won't comment on the L10 remark (damn I just did !!!).
  4. evildemon43
    maryborough
    vt ss 5.7
    not that I no it has not had any work done to it I only got the car 6 months ago but thanks for the advice and wat is L10
  5. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    OIL backwards.
    It might be worth getting the oil pressure tested, the oil pump might be wearing out.
  6. dirty hands
    dirty hands Active Member
    ipswich qld
    magna
    nut kracker does know his stuff as 2038 post show
    dont let that L10 info blow you out
    is that maryborough Qld
  7. evildemon43
    maryborough
    vt ss 5.7
    yeah that's Maryborough QLD
  8. Nut Kracker
    Echuca Vic.
    VT SS 304ci (195i)
  9. 9C1pack
    9C1pack Member
    Post deleted
  10. colourmesilver
    colourmesilver New Member
    Brisvegas
    VT1 98 SS 195i 5.0L 304 HSV ENHANCED
    Change oil every 5k, make sure it's not too thick
