vt stalling at running temp
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by vtseries2, Dec 27, 2011.
  1. vtseries2
    vtseries2 New Member
    new zealand
    '99 vt s2 3.8 v6
    hey ive been looking everywhere online and cant find anything that helps the car has a knock but only when on running temp. and then when it goes to idle it just stalls i can see a bit of oil loss as well the knock is coming from the inlet manifold or the rockers but the lifters has been check and tested just had a service and waterpump and thermostat replaced.
    PLEASE HELP
  2. ucwepn
    ucwepn America just kicked in yo
    WH statesman 5.7
    how long does it run before stalling? does it restart easily again after stalling? do the fans come on at all?
  3. Wombles
    Wombles Cars cost too much.
    Checked the error codes?
    Could be CAS.
  4. vtseries2
    new zealand
    '99 vt s2 3.8 v6
    it wont start up again until its cooled down if i drive it takes about 10 km or idle for about 30min then cuts out the fans come on and goes off like normal
  5. vtseries2
    new zealand
    '99 vt s2 3.8 v6
    it does not throw any codes or engine lights out at all would the knocking be caused by a faulty CAS
