ZXTC
- Apr 30, 2009
- 77
- 23
- 8
- VE SSV Sportwagon
Hi All
Just some info for people with starting problems due to the factory immobiliser not disengaging.
Read through lots of posts plus had the RAA out and came down to -- remote head flat battery, slip ring or BCM not working.
My symptoms where car would not start (turn over and would try), red light flashing still above mode button.
Had to press unlock/lock several times to start car. On rare occosions car would not start at all. Come back an hour later it would be fine.
Anyway took the car to Holdens and expected the worse (BCM replacement) but it turned out to be a half unplugged wire from the slip ring to a circut board.
Asked how hard to locate and was told just have to take the plastic surrounds off around the steering wheel and you should see it.
5 minute job but still cost an hour labour :-(.
So for those trying to diagnose maybe check the cable connections before taking to Holdens.
Car know starts first time as prior to this issue.
Cheers Mick
Cheers Mick
