hi , ive got a 98 vt commie 3.8 v6 , and sometime when i go to start it you have to put your foot on the accelerator and give it a rev otherwise it cuts out , and sometimes it doesnt crank over at all so you have to turn the key off and turn it back on and try again sometimes its just fine , any suggestions ? thanks
mine had the same problem i read somewhere on here to give the starter moter a tap with a hammer it worked great after that thee gear tilts sideways and when you hit it with the hammer it strightens it worked on mine btw if you dont know where the starter moter its located on the passngers side at the back of the moter go in behind the wheel under the door
