VT Strange Starting Problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Rod Harrison, Mar 13, 2007.
  1. Rod Harrison
    Rod Harrison New Member
    VT Executive
    My 1999 VT has just developed a peculiar starting problem. If you turn on the ignition and try to start it, it will just keep cranking without firing. If I then switch off and try again it will fire and start first time.
    Does anyone have any idea why this should be happening? The ECU is not showing any events.
    Rod.
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    My mates VT did this, I think it was a faulty ECU.
  3. vt_on_20s
    vt_on_20s vt gone ve s2 ss ute now!
    sydney
    ve ss s2 ute
    mines doing it, every now and then i start it and it makes a jolty bad sound then i stop and try again and it works very smoothly... no idea..
  4. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
  5. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    I had this problem a few years ago, it turned out to be a faulty ignition key module.
  6. vt com
    vt com New Member
    vt acclaim
    faulty crank sensor, is it mainly doing it after the car has been running?
  7. wrx884
    wrx884 WA's ASR Rep
    im goin through this atm but yesterday my car wont kick over at all now i got codes 31, 48 and 92 now i been told 31 is a faulty key head and needs 2 b replaced im gonna do that hopefully on tuesday i'll let u know how it goes as 4 fault 48 thats the cam sensor ive been told this rarly get a fault in it but works along with the key hence y its not kickin over. Urs mayb on its way out might pay 2 get it fix or looked at b4 ur stuck in ur drive way like me while u can stilll drive haha.
    the previous owner had this problem b4 i got it, they had it back n forth from holden a number of times but never found the problem so ive had the car 4 nearly 2 years now still with the problem but funny thing was my car went 8 months touble free so it was a lil weird. ive always thought it was the crank angle sensor as its a common problem 2 im goin 2 replace that aswell coz i have brought 1 but never fitted it.
  8. wrx884
    wrx884 WA's ASR Rep
    update on my problem could b worth checking found the culpret was the 1st wiring harness on the left in the pic behind that loom somhow water got inside the taped up wires and slowly started corroding and over the years and till last saturday the wire behind completly snapped coz of how much corrosion there was.
    those looms run straight 2 ur computer and is y it was playin havock with everything
