VT Supercharged Auto Trans problem
don0xer
2000 VX Calais 3.8L Supercharged
does it happen at a certain rpm? ie. 1500rpm coasting in 4th at 90k's? or does it do it in 3rd at about 65k aswell?
is the shaking your idle jumping all over the place?
oska
vx custom 600RR
your 3/4 band is stuffed
not a major repair but you have to take the box out
are you also having problems with reverse?
D3V14NT
Likes Shiny Things
Geelong, Vic
93 VP BT1 V6
band is also applied for 2nd, so there should be some indication when changing to second gear if the band is indeed failing.
To replace the band you'll need a few gaskets as the oil pump needs to come off for access to the band and if memory serves (can't be bothered going out to the shed to check) the valve body needs to be removed to gain access to the band anchor pin.
