VT supercharged into a VY
James_aitchison
Old Bar, NSW
VX Series II S Pac 3.6L V6
Just asking for a mate who gets a few commodores and wrecks.
Curious to know if the L67 is a straight drop into the VY, and switch ECUs. Or do you need whole wiring loom and change everything over from the VT?
0081
VY s m5 supercharged
No you will need a vy loom. You can use your stock NA loom and just extend some wires as needed as it uses the same sensors they are just in a different location.
Then get the supercharged tune burnt to your computer, or get a supercharged comp with your cars info burnt to it or get the new comp linked to your bcm.
Kinng
CrippleFK
30
Straya ~ QLD
VE Series 2 SV6
You will need to move the ECU and wiring loom I'm pretty sure.
Kinng
0081
Kinng
Not true, he can us his current loom and ecu they both need easy mods tho.
I kniw this as i did it in my car. I have a vy manual which i put the supercharged motor into. Used ,y loom and ecu.
Kinng
CrippleFK
30
Straya ~ QLD
VE Series 2 SV6
Oh ok, just extend the loom?
Kinng
0081
Kinng
Yep you have remove the tape from the loom and pull the plugs back tom there new locatio. I needed to cut and join about 6 to 7 cables. Each car will be differet depending on how the wires where placed in the loom when it was made. Half of mine just had to be cut ad untwisted from other wires in the loom
