vt transmission
MkyHnly
Croydon, VIC
VC SL/E 253 Project - BMW 328i Coupe Daily
i'm having some issues with my VT series 1 s pack and think it could be my auto trans:
- struggles to kick down a gear while cruising on a highway from 4th back to third when i put my foot down, it skips, makes a nice thumping sound and jerks the car forward and doesnt actually kick down (i have to manually do it with the gear selector in the console)
- sometimes makes the car hesitate when taking off with a bit of speed (such as pulling into traffic off a side street), usually when i dont come to a complete stop at a give way sign, but also happens if i want to take off quickly, it hesitates for a second then rev's really hard...
so my question is:
is it a TPS? i changed my original one to a TPS from the wreckers off a VS and it seems to help with the taking off and kicking down gears EXCEPT for going from 4th to 3rd
how much roughly is it for a transmission to be serviced?
how much roughly for a new transmission?
and can a transmission from a VS fit into a VT?
cheers
whitey08
VT executive
does anyone know whats wrong, I have the same problem with mine and was hoping someone could help.
As for a service for a transmision, should be around $200. I have been meaning to get mine done and see what they say but if anyone knows what is wrong it would be really helpfull.
db_notso
diagnostic technician...
sunshine coast, qld
vt v6, mods(susp brakesetc...)
suspect worn box or sticking converter clutch or sticking valves or sticking solenoids
do a trans service
find out if any codes stored using mechanics scantool
unless the fault had only beeen there since fitting the new tps likely not tps
MkyHnly
Croydon, VIC
i have found that this issue only happens when the car is hot... i was told maybe try changing plugs & leads as well as do a trans service. regardless i know i need to do a trans service and will also do those plugs and leads and see how i go.
cheers
large
33
townsville
VU II S pack
mine is doin the same i have a vu s pack ute and it also makes a ticking noise which over past 6 months has got noticabley louder
