VT v6 chip
Budgetvtskidpig
Bendigo
Nans vt Olimpic
Probably a dumb question but will the chip for the auto VT eco 6 work correctly if the cars been manualized, just read some reviews about better shifting and all that..
PappaYeet
Adelaide Hills
VT Berlina L67
If you mean it’s been physically mannualised it should still work ok. Can’t say for sure though.
Vin999
SA
VSedanS
Its still an auto box your just doing the shifts manually up all the time to drive
Budgetvtskidpig
Bendigo
Nans vt Olimpic
Just the 4 wire with diode trick tapping into the auto box electrics at the ecu, it's a standard auto box just manualised that way to hold first second and third for skids
Budgetvtskidpig
Bendigo
Nans vt Olimpic
its bogan 4 wire with diode manualised, you cut 2 wires from the ecu to trans then join them with the diode, lets you hold first second and third without changing itself for max mang just thought it may interfere with the chip if I end up getting one, runs shitty with pod filter and open side pipes and that's kinda what they promote in the description (works better with cold air intake and open exhaust)
losh1971
North Tas
VE Series I SS Ute
Being MAF based you probably need a new tune due to intake mods.
