Yes, you can fit them to either side. They're the same.
Rockers n pushrods all wear different so yes you could but no you should not. It may rattle. The engine bolts lm of the understanding as long as removed at a certain temp can be re used, head bolts nead to be removed in a sequenced pattern being the tourq down proceedure in reverse, outside to in also at a temp.Also have a question regarding the rocker bolts, can they be reused as Holden have told me they can be reused?
I also have the stock rockers and pushrods mixed up that should be a problem due to it being factory rockers?
Thanks in advance
it shouldn't be necessary and l wouldnt. But ask your machinest or call a engine builder.Thanks guys, when I got the head back from the machinist the rockers were just slapped in a bag, to my advantage is they are stock rockers and pushrods so putting them in any order should be fine?
Also, as I put the head bolts back in do I apply Loctite 567 or 242?
Thanks again really appreciate your help.
