Well there you go, l watched a genuin gm tear down and rebuild explanatory given to all service but do not recall any thread lock mentioned. Only a sealant across the sump ends from memory. I could be incorrect.All recommended Loctite 242 on head bolts but I think I will go with Loctite 456 for head bolts as it’s water resistant too?
If you mean GM genuine have it applied then l was incorrect saying it shouldn't be needed. I do recall seeing a bolt with what looked to have a grey coating on the thread but haven't recalled its pre applied nor have l had the heads off. I've in the past on cast blocks only torked down as was of the understanding thread lock can give incorrect tourq settings. Never had any issues either. An old school mechanic advice. If l was in your position l would have called Holden before hand. So that's why l mentioned call someone. I'm fearly certain a engine builder stated it was needed for high comp engines or boosted application but don't recall a n/a engine being a necessity. But l could be wrong.He said they come on the bolts itself, aftermarket bolts don’t have theeadlocker on it therefore Loctite is applied.
l researched the assembly criteria but it's related to a ls1. The tourq bolts are thread locked and the tourq to tourq angle were not.Your right, in saying that this is a Vy l67 with stock boost
l found this on a post..Head bolts: 34Nm then tighten a further 90 degrees in sequence (if torqued to90Nm during this step don't tightenanymore) Tighten a further 90 degrees in sequence a second time. Intake manifold: 15-20Nm.Hi guys,
Could someone please confirm with me the final stage of the head torque bolts will be 90nm torque? Thanks
Was for vx l67. Can't guarantee you...Hi guys,
