Vt v6 recurring fuel/tank pressure issue
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Justanf, May 18, 2020 at 5:30 PM.
  1. Justanf
    Justanf New Member
    Munno para west
    Efi vk commodore
    Ive got a 2000 vt v6 with a recurring problem of when there is the slightest bit of pressure in the fuel tank wont start or if im driving will start cutting in and out and hunt at idol if i unscrew the fuel cap and wait 15 mins it will be fine. Its not a constant problem just randomly happens. I have gone over all the fuel lines replaced one, new filter pump charcoal canister trying to work out what the problem is, but it keeps coming back
  2. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 6 speed Auto Wagon
    Faulty fuel cap?
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Charcoal canister buggered.
  4. Justanf
    Justanf New Member
    Munno para west
    Efi vk commodore
    Brand new
  5. Justanf
    Justanf New Member
    Munno para west
    Efi vk commodore
    Brand new aswell
  6. Vin999
    Vin999 Active Member
    SA
    Vsedan
    did you check and/or replace the fuel pump and pressure regulator, sounds like a faulty pressure issue :)
  7. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    I don't have an answer to your question but I do have my own question. Where did you buy the new charcoal canister? I tried to get one but no luck at all.
  8. Vin999
    SA
    Vsedan
    another thing check the filler neck breather valve, could have **** in it or partially blocked from old fuel line crumbles,
    Lex likes this.
  9. Justanf
    Justanf New Member
    Munno para west
    Efi vk commodore
    Ebay where all good things are found
  10. ant797
    ant797 Active Member
    bunbury
    vy s
    Second this if you hadn't checked it had a rodeo with a blocked breather kept stalling
  11. Justanf
    Justanf New Member
    Munno para west
    Efi vk commodore
    New fuel pump and swapped the regulator with my other car
