VT V6 - Throttle flat spot, is it crank angle sensor or fuel blockage
ConradJohns
41
Lyrup
Holden Commodore 1998 VT berlina
My beast has been sitting in shed. When I put it away it was on empty. Now I got it out and started it has a massive flat spot in throttle, but if I slowly push accelerator slowly it will rev up. It’s like it’s starved of fuel supply. Any help and direction would be appreciated
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Silly question, have you added fresh fuel?
losh1971
North Tas
VE Series I SS Ute
One thing I'm pretty confident it's not is the CAS.
Immortality
Staff member
Sth Auck, NZ
Throw in some injector cleaner and new fuel.
VSYoot
41
Near Avoca Vic
VS Ute/VP Berlina. Caring for a 597kW VE SS
Had similar syptoms with a dicky plug on the side of the coil packs
vxcalais_01
VX V6 Calais 3.8 2001
DFI Module fault or coil can do it sometimes. As others recommended, trying some fuel system cleaner is a good start. But the only ones worth using now are Liqui Moly in the Gold Can and the Penrite one for EGR Cat convertors etc. When you use them you will know why they actually work....they are borderline chemical weapons. Caltex used to have the best one for many years before these came along, not sure if still available.
  • Like
Reactions: Lex
trel
42
Victoria, Bundoora
2002 VXII Equipe Wagon
I can attest to the Penrite cleaner, our Mazda started getting the sulfur/rotten egg smell, possibly blocked/defective cat.
Ran a bottle of the Penrite through it before a trip to Ballarat with fresh fuel, haven't had a problem since. Engine revving smoother, and it's quietened the exhaust down a little.
  • Like
Reactions: Lex
