showbags
SENIOR EL'BAGO
VT Calais, BMW 135 m sport
so stealth. love it
JayRome112
Vic-Toga-Party
Wide Body Galant & VT V6 TT
Small update:
Was having some issues with the lift pumps, now using one lift pump mounted below the gear box (just under the yoke/prop shaft).
Cleaned up the engine bay, trying to hide all signs that it has turbos strapped to it..
Also upgrading intercooler pipes to 3" just to see how late boost will kick. 2.5" is a very responsive set up.
kangavxss
2002 VX SS
What can i add to all the other positive comments except for "THATS MAAAAADDDDD".
Glad you stuck with the car and what you wanted to achieve..nice work..
FlatOut 710
Yeah nah mate
Perth, WA
'97 VT Commodore S Pac
Dude I wished I had the money and knowledge to do something like this, looks awesome mate
elless1
VU SS
Love the stealth aspect of the whole thing, and the quality of the build. You have good taste, and well done.
JayRome112
Vic-Toga-Party
Its been a while since I updated this....
So I finally got sick of having to run the lift pump before running the car for cold start (to clear the build up over night). Also thought, why not try something different.
An XR6 turbo pops up on ebay relatively cheap and brand new... so this happens...
Reused existing manifolds to save time and money, just had to tweak them..
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Hi
Did it work & if so any problems?
Lex
IBLOWN
44
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
Can i make a suggestion? V band that crossover pipe instead of the 2 bolt flange. I had all sorts of problems with mine till i went V band. I couldnt get the bloody thing to stop leaking. It kept blowing gaskets.
JayRome112
Vic-Toga-Party
Hi
Lex
Worked fine, only issue was the oil return pump. You really need to put some decent coin into one, or it leaks as well. Although a cheapy from ebay did last over a year (but did weep some oil). Other thing to note is you would have to turn the return pump on before starting the car to suck any oil that has settled in the lines, or the turbos will leak on first start.
Hurm.... never had a problem before but will keep it in mind, although I never run gaskets (unless its the turbo). Did you run a flex joint?
