VT - VX Frequently Asked Questions
Mat263
33
Maryborough
vx
Hey i have a 2001 vx wagon and the other day the heater hose blew and now it wont start and the radiator is drinking water
Banawy
41
Doha qatar
Chevrolet lumina 2002
Hello .. I have chevrolet lumina 2002 its equivaent to commodore vt i guess .. The problem is with the ac unit it was stuck to window vents till i found out how to change it manually to the face vents through the hoses back side the dash board .. Doing a bridge between the vaccum hose and one of the hoses there .. Thing is i cant get the air recycling to be inside the car i can smell exhausts coming from the cars infront all the time. Can any one help me with that ?!
morley858309101416
perth
99VT commodore
hey is it normal not to be able to c the coolant in a vt commodore just wandering because the temp gage is on normal cheers in advance
wes.purcell
qld
hey
Hey guys need some help I'm doing a engine swap vx motor and put it in a vr and needed some advice on how I connect the vx wiring loom to the vr
oska
vx custom 600RR
People often ask what type of diff and ratio they have and there is often a lot of confusion
this applies to VT VX
My exec came fitted with factory LSD i never knew until recently
AXLE (Rear Axle / Diff Ratio) GU4 - 3.08:1 GU7 - 2.78:1 GU8 - 3.90
John Demetrioff
Carindale,Qld.
2000 3.8l vt series 2 holden commodore
hey guys, i just bought my first car a VT and i noticed theres like a thick brownish coloured build up in my radiator when i take off the cap and that its also on the dip stick.
do i need to flush it? and if so how do i go about doing that? cheers
holden used to put a pellet in coolant and this over time causes this thick brown sludge remove over flow bottle clean replace or flush system and replace new coolant ihad this and it worked out ok
Immortality
Staff member
Sth Auck, NZ
Hi and welcome to the forum.
You have just replied to a 8 year old post......
Please refrain from digging up old threads/posts unless you have something important to add. Those pallets do cause some issues but what that poster described is a classic symptom of stuffed head gaskets allowing oil into the cooling system. Common problem unfortunately (but you know that right ;) ).
Robert MB
77
Goolwa
Holden
Were there any VU Sedan's ever made ? I can't seem to find any anywhere, not even through google. All it turns up is VU Utes
Can anyone tell me ?
Utes were VU sedans were VX of the same year
lout
60
Langwarrin Victoria
deleted
