VT VX power window conversion wiring
hi guys
i am in the process of converting my vt executive with power windows.
i have bought the following from recos
4 regulators with the steel brackets
door trims with rear switches
center console power window switch
secure window with tape when removing the manual window winder (have to drill pop rivets in and a few nuts in front
conversion of the regulators are very easy - just open the door trims and put the new regulator with the steel arm in to the door. just need to drill the big poprivets to take the manual door winder out. i am just using 5-8mm nut and bolts when putting the new electric regulators.
drop the window down to the new power window arm and secure it with glue(silicon) and tighten the nuts in window.
the tricky bit is the wiring
i am planning to manually wire the windows through a new relay. i am planning to cut the power window connector in the console and do the wiring manually
has anyone done this? i just need a wiring diagram to do a manual wiring conversion
i found a picture of the diagram which i have attached with the rear of the power window switch. is this connections correct?
thanx for your help, hope someone will learn from this
hi guys
