danielnitschke
- Feb 16, 2015
- 70
- 4
- 8
- Location
- New Zealand
- Statesman WK 03 - LS1
Hello,
Recently downloaded the VT-VX Service Tech Manual ISO.
I extracted and tried to install it using the SETUP.exe.
The first window says "For this program to work successfully, this CD MUST be copied to your hard drive. Do you want to copy this CD to your hard drive?"
After clicking yes, the installer launches. I press OK to begin, and then this window pops up with an error.
I clicked ignore, and the next error that shows is exactly the same window but says "Object variable or with block variable not set". The one after that after further clicking ignore, is Run-Time Error 424. Object required.
I've tried this on three different PC's. One on Windows 8.1, Windows 7, and XP Pro. None wrk and all give the same errors.
What's going on?
Cheers,
Dan
What's going on?
Cheers,
Dan
