Chumpanator
- May 28, 2020
- 2
- 1
- 3
- Age
- 38
- Location
- Christchurch
- Vt executive wagon
0 0 0
HELP...
I've got mad priming issues, I've replaced coil packs, fuel filter, fuel pump, fuel pressure regulator, injectors, plugs and leads even spent up on harmonic balancer removal tool and rattle gun just to replace the crank angle sensor, even ripped it open and replaced my air inlet manifold and rocker cover gaskets and cleaned everything up but still have the same issue.
It wont start unless it's been running, to get it started I have to leave ignition on for 5 minutes before cranking and then it fires no problem.
Obviously its having a torturous effect on my battery but I'm not giving up on it.
Fault codes showing torque converter solenoid fault but that's all.
It's like the fuel in the lines magically disappears.
I've tried everything I know please help me put this to rest
HELP...
