VT Wagon Fuel Issue
Chris Tinkler
VT Wagon
Hey lads,
I recently picked up a VT wagon I've been using for work which has a low fuel issue.
So after filling the tank up full, I can only use about 60L before the car has issues starting and running if I'm on any sort of incline and/or parked in the gutter.
Before I start investigating it myself thought I would check if any of you know anything that would cause this?
Thanks
Chris
accentstencil
72
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Low fuel. What you have describes above is normal, especially when parked uphill or with the car leaning excessively to the left. Don't let it run so low on fuel.
Chris Tinkler
VT Wagon
Thought with 10-15L in the tank it wouldn't be "low" enough to cause issues, I always fill up arround then anyway just thought with a 75L tank the pickup wouldn't have an issue with the car parked on a slight lean to the left. Cheers for the reply
