hey all today as i jumped in my vt 2000 acclaim i noticed where the cluster says the kms the word "Error" with a chime or alarm going off poped up aswell as the warning lights abs,traction off,engine check light, and airbag lights all go on with the high speed fan going non stop in the engine bay, i pull over turn the car off then turn car back on and thought this fixed the problem but 5 min later of driving the same thing happend, what could this problem be? the car isnt overheating or anything so its axcting strange one problem is setting off all! any help appreciated!
Try check for codes. http://forums.justcommodores.com.au/holden-commodore-how-tos/23665-checking-error-codes-vt-vx.html
1) The coolant sensor may be faulty, sending wrong signals to the PCM. 2) The fan relay may be stuck on. Pull the relay out and start the car. See if it makes a difference. Don't let it run too long, or it will over heat without the fans.
