VT water pump gasket sealant
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Dougthe37th, Dec 4, 2011.
  1. Dougthe37th
    Dougthe37th Donating Member
    Pt Vincent
    VX SS
    Hey guys I have to put a new water pump on my VT but I have ran out of gasket goo(That blue stuff) and I have Form a gasket(that black stuff) will that work to put on the gasket? or is that 2 dodgy
    Thanks Doug
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    On the occasions that I have changed a water pump I simply used the gasket only, no leaks.
  3. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    I personally always use blue goo....No leaks yet! but have never not used it....but i'd say it should be OK..
  4. Dougthe37th
    Pt Vincent
    VX SS
    cool thanks guys
  5. illlusion
    illlusion Member
    VE SSV MY10
    if its the the black goo in a orange tube is fairly runny and makes a mess and does not always seal take ages for it to set i always use the blue goo
  6. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    I use the blue Permatex silicone, no leaks. Personally I wouldn't put it on dry.
  7. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    I always use Loctite 515 for water pumps, thermostat housings, etc. Never had a problem and I plan to keep on using it.
    Holden (or whoever makes the Colorado) also uses it from factory to seal the front wheel hubs instead of a gasket.
  8. GRPABT1
    GRPABT1 Jakstas' Warden
    The ville
    VN shitta
    Loctite number 3
  9. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    as Above /\/\/\
