VT wiring harness??
dbun
VT Berlina
Just bought an Aerpro wiring harness to do my headunit in my VT berlina and noticed that it does not have a black ground lead on it. It's got all the other relavent colours but no grounding lead.
Is it supposed to or does the grounding wire not run through the harness??
garfa
34
SE Victoria
VY SS
run a new ground. stock grounds can (and are) not as good as the ones you make yourself.
StoneX
41
Hastings
VE Calais-V 6.0L
I have a VT Berlina and used a wiring harness... I can't remember what colours each wire was but I didn't have to run a new ground or anything.
dbun
VT Berlina
yeh.....was thinking i should just run my own ground.
What about the power antenna wire though?? The Aerpro harness i bought doesn't have a power antenna lead on it??
I'm unsure what to do with the power antenna wire from my headseat loom as it doesn't join up to the Aerpro harness
StoneX
41
Hastings
VE Calais-V 6.0L
Is this the loom you got? It is the model 711784H which suits VT Commodores. It has a black earth wire. I can't remember about the electric antenna wire because my head unit (Pioneer) doesn't have electric antenna wire, just remote wire so it was connected to the blue wire, as far as I remember.
dbun
VT Berlina
I bought the AP1784H (below) because it said "connects to OEM harness to enable connection to aftermarket head unit."
Did I by the right one??
StoneX
41
Hastings
VE Calais-V 6.0L
Yeah, sorry, my mistake... I don't know what the point of the one I listed is.
Do you still have the packaging? Mine said what each wire was and there was an earth. I tried looking under my dash but I couldn't see the wires unfortunately :(
dbun
VT Berlina
yeh still got the packaging.....but not all the colours listed on the back or on the loom eg
pink=mute....not there
black=ground.....not there
blue=power antenna.....not there
orange=illumination....not there
orange/white=dimmer.....not there
i'm thinking maybe the antenna wire from my h/u goes to the blue/white remote on the wiring harness as there is no blue power antenna on the harness
i wouldn've expected a grounding wire though
thanks alot for the help so far mate.....really appreciate it
Muttley
52
VT2 Berlina
Hi dbun,
Went through some pain getting the antenna working on my VT, but is actually quite simple. Here is the guts of it.
1. If you use the wiring harness as most people suggest, then it will connect the blue wire from the HU to the Yellow/Red in the wiring harness. This tells the antenna control unit that the radio is on. It doesn't supply power to the motor, this comes directly from the battery.
2. If you had the antenna up when you took out the old HU then it should go back up to that spot when you hook up the new HU.
3. If you had the antenna down when you replaced the unit (like I did) then the antenna stays down. Read on to find out how to fix it.
There are 2 wires in the harness to control antenna UP (Light Blue) and DOWN (White). To control the antenna height, connect EARTH to either the UP or DOWN wire. Not 12V. Once you have it in the spot you like, simply leave them unconnected in the plug and the antenna will return to that spot when the HU is on and go down when the HU is off.
If you want to control it, you will need to put a 3 way rocker switch somewhere to switch EARTH to either wire.
You should be able to find wire colours and a schematic here on the forum. Both helped me heaps but feel free to email if you have any questions.
BTW I ran a separate earth for the unit.
Muttley
dbun
VT Berlina
Thanks for the reply Muttley
just with the antenna.....i thought the commodores automatically retract the antenna when you turned of the car?? So do you mean you have the antenna physically up when you remove the H/U??
