my 98 vt wont start it will wind over but wont fire it was running fine then went to pull out of my drive way and it just died i only replaced the fule pump a couple of months ago so it has me stuffed as to what it could be also the thermo fans dont work im starting to think there could be an electrical problem but any other thoughts would be great TIA
Maybe got a dud fuel pump. Check the fuel filter. Check all your fuses and fusable links under the bonnet and in the car. Don't go by how they look, test them properly. Also check the fuel pump relay and fuse. If it just happened after you got the new pump, I'd be checking around that first. Have you added a tacho? If the the signal wire of the tacho shorts to earth, no way the car will start. It happenned to me.
checked all fuses and filter and all r fine but i have been told it may be the crank angle sensor so will relace that and see how it goes bcoz everything else seems to be fine thanks for ur advice greatly appreciated
