VT2 factory immobiliser
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by hsv_sc, Aug 23, 2008.
  1. hsv_sc
    hsv_sc New Member
    HSV GTS Commodore VT2
    i've got a HSV GTS VT2, factory immobiliser has developed a fault after replacing battery.. :cry:
    anyone know how i can get the car started so i can get it to a dealer for repair or what part to replace if this is something i can do myself?
    thanks all. :)
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Suggest you check all your fuses and reseat all the relays. When you say the immobiliser has developed a fault, what sort of symptoms are you getting?
  3. hsv_sc
    hsv_sc New Member
    all fuses and relays checked..
    no fuel pump or starter when switching ignition on, after 10 secs, 3 beeps from behind dash.
    this is definitely the factory immobiliser.
    i just need to get it going to take it to a dealer for repair.
  4. fasamr
    fasamr New Member
    vt 3.8 ltz
    after switching on the switch press the unlock button on the topo of the trip computer menu but the led will stop flashing then u can start the engine
