vtss 5.0 looses power
whosup
sydney
corolla ke30 with VTss 5.0
hi
i have a vtss 5.0 engine and after about 10min it starts looseing power and gets worse over the next 5 min then start to back fire then wont go at all, when it cools down it starts and does the same thing all over again any help would be great thanks
db_notso
diagnostic technician...
37
sunshine coast, qld
vt v6, mods(susp brakesetc...)
unplug coolant temp sensor when it starts playing up it will have reduced power but keep running
this is the first thing i would check...
whosup
sydney
thanks ill give it ago
db_notso
37
sunshine coast, qld
if this does no thelp fault
it sobviously temp related
time to check coolant for oil and oil for coolant...
if no milk found
get codes checked to see if any stored like
"fuel pump relief circuit" or "engine overheat warning" or what ever and post it up
whosup
sydney
checked the coolant and oil it seems fine so ill check the temp sensor tomorrow
db_notso
37
sunshine coast, qld
too easy ill jump on here tomorow night and have a looksie~!
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
coil getting hot/failing, ignition module failing or dizzy hall effect sensor dieing would be my first guesses
db_notso
37
sunshine coast, qld
these are also possible and worth a check next (i agree with ya!)
whosup
sydney
thanks i will check those aswell
