Guys, I have just fitted a VT V6 into an old Hilux. I used an auto ecu , with the chip rewritten with a manual ROM and the immobilizer and fan functions switched off. The engine starts and appears to run ok.
Problem being is I cant seem to get the scan tool to talk to the ECU. I have wired an OBD plug using the pin 5 an6, and the 12v power and serial data pin. From what I can see, the check engine light runs from the body module.
Can any one suggest what I may have missed or not understood ?
As well, by not hooking up a speed sensor, will it affect anything apart from lean cruise at higher speed ?
Cheers Mike
Cheers Mike
