Fleash
hey guys had this problem ever since i put a vx motor into my VU ute, i hit flood water at the start of the year and blew a hole in my block so did a engine swap, the vx motor idles at a steady 2k, just tap the throttle and shoots up to around 3-3500 hangs for about 2 secs then slowly returns to 2k. i have done multimeter readings on all the sensors and they seem to be fine aswell as the maf/tps/iac valve. it will run for around 2-3 mins before the engine light is displayed but my code scanner isnt picking it up. when i start the car again after it displaying the engine light it dosnt come on untill it runs for a few mins. checked for vacuum leaks with a can of carbie cleaner but to no avail. also it gets quite hot really quick, would anyone have any clue as to what is goin on or what i could try to fix it? both motors are ls1 gen 3's cheers in advance
