Hey guys entering new territory and am interested in buying a Vu ss with the ls1 but it has 190ks and just wondering average life out of these rigs,box and autos? Common problems ? Any feedback I should know thanks guys
I wouldn't be too concerned about the km's. There should be plenty of life in the gearbox and engine as long as it has been regularly serviced. Look for engine noise on cold startup as the ls1's are notorious for piston slap. I'd also be looking for signs of oil use as one of my old ls1's used about 5L/10,000km. Around 150-200,000km is when you'd expect the rear main seal to need changing and its a big job (can be $1000+). Have a good look for signs of oil leaks and consider that if you're planning to make an offer.
Thanks mate all the info I wanted so as long as it's looked after it will be okay I only asked because the cars in melbourne which is 1 hour and a half and sorta wanted an idea what to look for thanks mate
I would not be put off by a little bit of cold start piston noise as the LS1's tend to be a bit noisy when cold (as long as it is not excessive), take it for a run and get it up to temp then have a listen, if it is nice and quiet when up to temp I would not be too concerned. As said above check the dipstick and see where the oil level is sitting, some LS1's do use a bit of oil, not all though.
