VU struggles to rev over 3000rpm
sunshine the vu
27
tweed heads
2001 vu ute
hi every one i've got a problem thats just occured my 2001 vu ute struggles to rev up and or over 3000rpm
what could be causing this problem its a v6 btw if that helps.
Bowen
Alstonville
2002 VX S manual 3.8L SP
Will need a little more information.... But my guess from your description would be blocked fuel filter ($15 easy replacement), and try and get a hold of a known working dfi module and coil towers from a wrecker or a friend and swap it over into yours and see if it fixes it.... If it does buy it or buy new (I recommend new), and if it doesn't give it back to the wreckers they're pretty good depending on where u go...
Other cheap checks, check for vacuum leaks you can use carby cleaner and spray all over all vac lines and if idle changes you know u got a problem, check for any discrepancies with injector pulsing (use a screw driver stethoscope), and if u have a fuel pressure gauge test the pressure at the rail.....
sunshine the vu
27
tweed heads
2001 vu ute
fingers crossed i will change the fuel filter this weekend i hope. and ill check my vacumm hoses when i get the chance its idling fine and all sits just below 1rpm im not sure if thats normal but it seems it
thanks for you help btw i live on the gold coast and i got a commodore wreckers and specialist pretty close to me that only wreck and work on holden's so if i cant find the problem i might drop it in to them to have a look at
Olive Xm
On the edge.
VT
Is it the single catalytic converter type exhaust? a blocked or collapsed cat can do that.
sunshine the vu
27
tweed heads
2001 vu ute
Reading a couple of other threads i wont rule out the cat as it seems like it could be that is there anyway to check if its the catalytic converter?
Jxfwsf
Aus
commodore
Drop the exhaust off the back of the cat, shine a torch in there and look.
sunshine the vu
27
tweed heads
2001 vu ute
What should it look like or will there be a big turd my engine has **** out into the cat? Lol thanks for all your help bythe way
Jxfwsf
Aus
commodore
kinda like this without the leaves
sunshine the vu
27
tweed heads
2001 vu ute
I see really clogged up well ill try get the pipes off when i get some time off work and have a look and i also get a really shitty rotten smell in my car sometimes and ive been told thats the cat causing it
