Percy0654
- Sep 30, 2012
- 12
- 0
- 0
- Location
- Seymour
- VU S2 Storm Ute.
Don't know exactly how well the video will go. My most irritating issue here is the noise at the tailpipe. I have spent a few weeks and $$ chasing this down and am fast running out of ideas.
New parts:
Plugs
Leads
LIM gasket and all gaskets before it (blown out around cylinders 4 and 6)
Exhaust gaskets (weren't any there or sign of ever being there)
Oil, filter and coolant
Ribbed idler pulley as it was making a horrid noise
Battery terminals as the factory +'ve one broke
Replaced parts off another motor I have:
IAC
TPS
Injectors and o-rings
Fuel pressure reg
Coil packs and module
EGR
Valve cover gaskets were leaking, i've sealed them with some loctite till i can get out and get new gaskets
Cleaned MAF
I have checked relays all seem fine
Repaired the wiring at the coolant temp sensor as it was stuffed
Compression test results
1 - 155psi
2 - 155psi
3 - 157psi
4 - 152psi
5 - 155psi
6 - 155psi
Cooling system was flushed both radiator and block seperately.
Only code i've seen is 0012 which as far as i can find is all normal.
I think that's it. Anyone have any idea why it'd sound like this? Can feel the vibration when stopped at lights and idle is noticeably down on gauge, done this in diag mode to get rough figures idle was at about 750 before all this now goes between 750 and 850. 850 when cold just started, sits at around 800 just sitting at lights. drops to 700 if you use the throttle to hold it at 900 and release it and then slowly comes up to 750.
when driving, otherwise it's unnoticeable. even being in neutral and slowly braking towards lights it seems to hold the right idle until the car is at a complete stop.
I'm going mad trying to find this so any help at all would be appreciated.
Thanks in advance
Tom
